We are tying to improve the quality of our isometics and reduce editing. See attached picture. The slope symbol is blotted and overlapping the insulation. Text is overlapping its container box. Handwheel symbol is blotted. How do I change these?
Hello Sean,Can you please check the Level of Slope's Cell?Steps to Verify1. Go to Elements --> Cells
2. Select 'ELEV' --> Open for Editing.
3. Check the level of Slope.
4. Save Settings and thenGenerate Isometric.HTH, lets us know if you have any further concern.Regards | Jaya
Answer Verified By: Sean Crowley
Hi Jaya,
Thanks again for your help.
What do I need to be in for this, when i'm in the seed file the list is blank, when I am in a generated isometric I'm not able to edit the ELEV field (the funcion is greyed-out). Is it through the cell library?
Kind Regards,
Sean
Hi Sean,
You need to add Lisocomp.cel file to load all cells available, then only you will get ELEV cell.
I hope this will help.
Regards | Abhilash Panchal
Regards, Abhilash Panchal Product Engineer - Bentley Systems
Are you a CONNECTED User? Click here to find out more.
Find out whats inside Connect Advisor Update 2. Click here
Produce 3D models of existing conditions and Bring them to life!!
Hi Abhilash,
Thanks for your reply.
Thank you, I did this in the seed file and the level is 20 and the weight was set to 5. I set the weight to 0 and generated another isometric but there was no change. What level should it be on? When I went back in to check, the weight automatically went back to 1
We checked default settings and those re same as Screenshot which you attached.
I thing this should require some thorough investigation. Please log Service Request so that one of our analyst will contact you and help resolving this issue.
Refer below article for logging Service Request.
