We have been generating our BOM from a custom property called ITEM with all of our PIping Components.
this.PIPE_MATERIAL is a property that users select from a drop down menu. It has a select few options generated from the PIPE_MATERIAL_VALUE_MAP
In Openplant the Display Label is shown when we select the material, but the ITEM description shows the Name (with underscores)
We would like it to show the Display Label in the ITEM description as well. Is this possible?
Class Editor V8i - 08.23.01.66
OpenPlant V8i (SS5) - 08.11.09.568
Brynn Paluck
Hello Brynn,Thanks for asking your query on Bentley Plant forum.
When a record is picked using value map, it picks its name rather than defined display label. As per your above query we suggest you to enter material name without underscore in name field instead of display label field.
You may refer below wiki article as an example. Rating Value Map Issue in OpenPlant Modeler Applies To Product(s): OpenPlant Modeler Version(s): 8.11.11.87/96 (SS6) & above Environment: Windows 7 (64-bit) | Windows 10 Area: Component Subarea: Data… Last edited over 7 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
Also, it would be great to have a service request to capture this query as an enhancement. Please raise a service request using below wiki link. How to Log or Report Service Request for Bentley Plant Products Product(s): OpenPlant Products Version(s): All Bentley Products Environment: GENERAL Area: N/A Subarea: N\A Overview How to log a SR informing of any problem… Last edited over 4 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
HTH,Regards | Deepak Singh
This helped:
OpenPlant Tech Tip Tuesday - How to Set Pick List Values as Numbers OpenPlant Product Manager, Abbas Ali, shows you how to set pick list values as a number with OpenPlant CONNECT Edition in this edition of OpenPlant Tech Tip Tuesday! By Amanda Brewer over 5 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Announcements Forum 0 replies
Extend Type
Answer Verified By: Rahul Kumar
