hi all,
we use flexible hose in pipelines that are being insulated. we set the flexible hose without insulation. But if we change something in the pipeline manager the insulation from the pipiline goes over to the flexible hose. The second problem with insulated flexible hose is that the dimension of the insulation grow up by everytime we open the file in OPM.
here you can see the destroy flexible hose:
at the first moment if we are the the component all is normal:
we use the OPM version 09.568 and the OPIM version 09.574.
anyone an idea ?
Markus
Hi Markus,
Thanks for raising your query on Plant Forum.
Please can you attach DGN file for our reference. Is it happening to all of your DGN or issue is specific to DGN?
Also, I thing this issue needs thorough investigation for that Please Raise Service Request for same so that our analyst could get in touch with you.
You can refer below WIKI link to Raise Service Request.
Regards | Abhilash Panchal
Regards, Abhilash Panchal Product Engineer - Bentley Systems
Are you a CONNECTED User? Click here to find out more.
Find out whats inside Connect Advisor Update 2. Click here
Produce 3D models of existing conditions and Bring them to life!!
8272.Test.dgn
here i had upload an test file with our flexible hose. the effect is by all our DGN and by different projects.
Hello Markus,
Thanks for providing DGN File.
My question here is what changes you are making in Pipeline Manager after which insulation goes over Hose.
For your second query, Flexible hose Insulation dimension is getting increased as you mentioned. But, this issue is not getting reproduced in OpenPlant Modeler Select Series 6 version 08.11.11.304.
It would be great if you can log Service Request for this, that will help in getting Root cause of this issue.
