hi all,
we wonna show the max. sheetnumber of the pipeline on the drawings, so you can see this is iso 1 of 3 isosheets.
if i open an iso in isometrics i can found under drawing tag data the information "no_sheet" that shows the highest sheet number of the pipeline. But i dont found this data field in the text node editor.
Where i find this data field no_sheet in the schemas and how can i add to the list in text node editor.
Here you can see unter point 17. this like we wanna get it: https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/23069/how-to-format-number-property-in-isosheet-name
Markus
Hello Markus,
Check below wiki article for your quick reference.
How to Use Various Iso-Sheet Splitting options in OpenPlant Isometrics Manager Applies To Product(s): OpenPlant Isometrics Manager Version(s): 08.11.11.224 (SS6) Environment: Windows 7/8.1/10 (64 bit) Area: Settings/Attributes Subarea: Isometric… Last edited over 4 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
HTH
-Regards | Rahul Kumar
Rahul Kumar
Answer Verified By: Markus Wilbers
i forgot to say we use the OPM version 09.568 and the OPIM version 09.574.
so this option only work with SS6 ?
Hello Markus Wilbers,
You can add this node NO_SHEETS in node2da.txt file present in your style folder config. See below image:
This will list this Text node on Text node editor. Later, you can place it wherever you want.
Also, just for reference you can refer below WIKI where a similar case is been shown.
Hope this helps.
Regards | Abhilash Panchal
Regards, Abhilash Panchal Product Engineer - Bentley Systems
Are you a CONNECTED User? Click here to find out more.
Find out whats inside Connect Advisor Update 2. Click here
Produce 3D models of existing conditions and Bring them to life!!
k i have check this and its work fine with SS5, thx for your help. next time i should look more precise in the wiki.
