请问oplenplant molder和pid中水晶报表如何定制,有没有相关教程。
Dear YjZ,
Thanks for posting your query on Plant Forum.
Please go through below WIKI for OPPID where Crystal report & Template is been created.
Also, for OpenPlant Modeler you can follow below WIKI where Learn Server link and Technotes link is provided.openplant reporting faq
Hope this help.
Regards, Abhilash Panchal Product Engineer - Bentley Systems
Are you a CONNECTED User? Click here to find out more.
Find out whats inside Connect Advisor Update 2. Click here
Produce 3D models of existing conditions and Bring them to life!!
Dear yj z,
Thanks for posting your query on plant forum!
You may check below wiki article where small discussion was made.
OPPID - How to create a new report using Crystal Reports Applies To Product(s): OpenPlant PID V8i Version(s): SELECTseries 3+ Environment: N/A Area: N/A Subarea: N/A Original Author: Bentley Product Advantage… Last edited over 6 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
With latest connect version of OpenPlant Modeler and OpenPlant PID, a new utility has been introduced which makes the customization easier. In case you need some more assistance you may write your requirement.
Also you can post your query on China first community (另外,中文问题建议您到中国优先社区提问,地址:)
HTH
-Regards | Rahul Kumar
Rahul Kumar
