Please let me know the how can a block created using Autocad 3d commands is become intelligent in autoplant Equipment Modeling.
Intelligent mean including tags/equipment number,etc.
Please guide.
Hi Amanpreet Syall,
Thanks for Posting your Query on Plant forum!
We are currently checking Possibilities of this request and will update you shortly on this.
Meanwhile, you can check below WIKI where all information are listed in WIKI article.
Regards, Abhilash Panchal Product Engineer - Bentley Systems
Are you a CONNECTED User? Click here to find out more.
Find out whats inside Connect Advisor Update 2. Click here
Produce 3D models of existing conditions and Bring them to life!!
Thanks for you reply,
I will wait till further information provided by you.
Hi Amanpreet,
Thank you for posting your query in Plant Forum.
Intelligent block containing Equipment information is called Custom Equipment in AutoPLANT Modeler.
To create a custom equipment containing intelligent data using basic shapes please refer the steps below:
1. Launch an Equipment model from Bentley Document Manager.
2. In a loaded model from Equipment menu select Equipment primitives and place a rectangular blocks.
3. Create a tag for the Equipment.
4. Select the dimensions of block.
5. Double click on primitive and you must be able to change the tags.
6. Similarly use Equipment primitives, associated primitives and transition components to create Custom Equipments.
7. Place a nozzle on the Equipment.
8. The nozzle will be associated to the component.
Hope the required steps help you to create a new Custom Equipment. If you have any similar query please create a Service Request so that we can take it on priority and help you.
Link to create Service Request:
How to Log or Report Service Request for Bentley Plant Products Product(s): OpenPlant Products Version(s): All Bentley Products Environment: GENERAL Area: N/A Subarea: N\A Overview How to log a SR informing of any problem… Last edited over 4 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
Regards | Swapnil Joshi
Thanks Swapnil for your response.
Actually in above process we can create a custom equipment using Autoplant component shapes available in the software.
But if i created some Lighting Fixture 3D block in autocad 3D Modeling or i get 3D block from the vendor then how i will import that block in Autoplant and make him intelligent.
Intelligent mean including its tag/equipment number and its other information.
Thank you for the quick confirmation. You can import the geometry in AutoPLANT and use this User Defined option to make it intelligent.
Once it is clicked we will be prompted to create a new Equipment tag.
Select the Entities.
Enter the required parameters.
Click on OK.
Your Custom Equipment must have intelligence.
Hope this helps to create a custom equipment with existing blocks. Your feedback would be valuable.
Thanks.
Regards | Swapnil
Answer Verified By: Amanpreet Syall
