When I launch "OpenPlant Isometrics Manager V8i in AutoPLANT access mode", I recieve the following error 'Object reference not set to an instance of an object'... However, I don't encounter any problem when I do the same through Sample Metrics....
I am also encountering same issue on OpenPlant Modeler (CE). This is happening with one particular model file only. May I know if this has been resolved? If yes, could advise me the solution? Thanks
Dear Kyaw
Above issue relates to AutoPLANT Modeler with OpenPlant Isometrics Manager.
if you please provide steps you did with OpenPlant Modeler with OpenPlant Isometrics manager then we would be able to assist further.
Rahul Kumar
Dear Rahul,
I didn't do any steps yet. It is just appearing whenever I open that model file. I just clicked Ok and opened. It works like normal model file but just appearing that error message when open.
Thiha
