Pipeline tag syntax is simple: SYSTEM-NUMBER (Ex: ACW-001).
Want OPM to create levels on the fly as:
M-PIPE-SYSTEM-NUMBER (Ex: M-PIPE-ACW-001)
Hello Mike,Thanks for posting your query to Plant forum, please refer below wiki article that will help in achieving your requirement.
Perhaps you copied the wrong article? This seems unrelated to my question.
I'm talking about level names in the level manager. Right now, I'm creating 3 levels in each file from a template. PIPE, CENTERLINE, and INSULATION. I have a template for each SYSTEM, and the symbology is set based on the SYSTEM code. However, all my PIPE is being placed on one level (M-PIPE).
What I want is for OPM to create a new level for each pipeline based on SYSTEM & NUMBER so that each pipeline is on it's own level. Level names would follow this syntax:
M-PIPE-SYSTEM-NUMBER (Ex: M-PIPE-ECWS-001).
Can anyone shed some light on this for me?
Hello Mike,
I would request you to please raise a service ticket on this request so that we can have proper investigation on your raised concern.
Regards | Deepak Singh
I think this wiki article could be what you're looking for:
How to Edit Pipeline Level Naming Rule in Named Expressions Applies To Product(s): OpenPlant Modeler V8i Version(s): 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) Environment: Windows 7/8.1/10 (64 bit) Area: Settings/Attribute … Last edited over 4 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
Best regards,
Tuan
Edit: change wiki link to a more relevant article
Answer Verified By: Mike.McGinnis
