My question is more about the general usage of object enabler files. I am working on a project with another design company. They are using Autodesk Fabrication MEP to model plumbing piping. I am using OpenPlant Modeler V8i (SS6) v 08.11.11.304 to model process piping.
They have supplied me with their .DWG file, and several .EXE files for OEs from varying versions. I have ran every one of them, but I still get the "One or more Object Enablers is missing" error when I try to open their .DWG file with my OPM.
Is there something I'm missing here? Is there a certain place where the OE needs to be installed? I just went with the default path (c:program files.../Autodesk...etc...).
Can anyone shed a little light on this for me?
Regards-
Rahul Kumar
I keep getting an error when I try to attach the files. Is there another place where I can upload them?
Hello Mike,
Could you please upload your file in below link:
https://bentley.sharefile.com/r-rc5a8b0985544009a
Abhijit Bute
Also Please provide your direct number so that we can reach you in case any discussion required.
HTH
-Regards | Rahul Kumar
Hello Abhiijit,
Was anyone able to take a look at the files I supplied?
