How do I resolve the following issue highlighted below.
[8/3/2018 5:12:49 PM] Loading 1 i-models======================================================================================================================== Starting i-model engine i-model master unit 'Feet' is not matching with 'MILLIMETERS', specified as PROJ_MASTER_UNIT in OP_Modeler_V8i project pcf. You might have selected wrong workspace project or i-model.
[8/3/2018 5:12:51 PM] Loaded 0 out of 1 i-models------------------------------------------------------------------------------------------------------------------------
Openplant Modeler v8i (SS5) - 08.11.09.568
Openplant Isometrics Manager (SS5) - 08.11.09.574
Thank you.
Hello Ibrahim,
This mainly happens because of different project unit selected. Refer below wiki
error i model master unit feet is not matching with millimeters specified as proj master unit in opmodeler mmetric project pcf you might have selected wrong workspace project or i model
HTH
Regards | Rahul Kumar
Rahul Kumar
