In my Isoseed file, I have the dimstyle set to include the dash ( - ) between Ft & In (Ex: 12'-0"), but my ISOs are coming out without the dash (Ex: 12'0").
Any help?
Hello Mike,
Thanks for your question. Could you please change following variable in Style.cfg.
IE_FMT_DIMENSION_FEET_INCH_SEPARATOR = @-@
Also please refer following communities which will guide you detail steps:
How to Remove Space Between Dimension Value and Unit in AutoPLANT - OpenPlant Isometrics Applies To Product(s): OpenPlant Isometrics Manager Version(s): 08.11.11.224 (SS6) Environment: Windows 7/8.1/10 (64 bit) Area: Settings/Attributes Subarea… Last edited over 4 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
Hope this helps. Looking forward to your reply.
Abhijit Bute
Answer Verified By: Mike.McGinnis
