Hello All,
I placed a pipe run terminator at the end of a pipe run, I can see the pipe run is connected to the terminator in To From Data, but it is not show in the piperun General Info, thus no connection data in DataManager. Is it a bug? I know I can input the To From data manually in piperun General Info, but it supposed to be filled automatically.
Hello Changsong,Thank You for posting your query in Bentley Communities.Can you please confirm your SS5 version of OpenPlant PID you are using?Also, would like to inform you that in latest V8i SS6 version it is working fine, see below image.Please confirm your SS5 version so that we can help you more on this.Regards | Jaya
Hello Jaya,
Would you please try the piperun terminator what I highlighted in the picture? No problem if connect to equipment or pipeline. Thanks a lot!
Thanks Changsong for quick comment.This is an Enhancement, so please log New Service Request for this, so we can log an new Enhancement Request.Refer below link:Regards | Jaya
