OPM Connect 'bmech rebuild' key in
HI ,
With OPM connect version bmech rebuild command is stopped working,
Please respond if have any idea for alternate key in option,
Our requirement previously we were able to change piping component insulation thickness from property dialogue box in OPM v8i, although the graphic of it was not changing,
But we were able to change graphical appearance  by bmech rebuld command in OPM v8i, which we can't do anymore in OPM connect version.
Vivek
Parents Reply
  • HI Rahul,
    I am not sure this would help us,
    In our case we have a pipeline containing 4 different sizes of pipe at beginning all them had insulation thickness of 100mm, now insulation thickness is updated of different values for each sizes.
    There should be some way to represent in OPM connect without 'bmech rebuild'.
    Though it's good news that later connect version would resolve it, but it sound impractical to take away existing solution without replacing it with another solution Slight smile
    Vivek
