Unhandled exception error
 I received this error when entering a drawing - It comes up just after the command line displays "COMMAND"; any ideas what could be causing it?  when I click OK, it seems to progress into the file just fine.
Is there some place to find more detail - when I pull down the detail menu it just shows me what is displayed above then lists all the loaded assemblies as follows:
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
acdbmgd
Assembly Version: 17.1.0.0
Win32 Version: 17.1.219.0
CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AcdbMgd.DLL
msvcm80
Assembly Version: 8.0.50727.3053
Win32 Version: 8.00.50727.3053
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3053_x-ww_b80fa8ca/msvcm80.dll
acmgd
Win32 Version: 17.1.51.0
CodeBase: file:///C:/Program%20Files/AutoCAD%202008/acmgd.DLL
AcCustomize
CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AcCustomize.DLL
acmgdinternal
CodeBase: file:///C:/Program%20Files/AutoCAD%202008/acmgdinternal.DLL
AcCui
CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AcCui.DLL
AcCustomize.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%202008/en-US/AcCustomize.resources.DLL
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Windows.Forms
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
AcMNUParser
CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AcMNUParser.DLL
AcInfoCenterConn
CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AcInfoCenterConn.DLL
AdInfoCenter
CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AdInfoCenter.DLL
Autodesk.Interop.AcInetEngine
Assembly Version: 17.1.51.0
CodeBase: file:///C:/Program%20Files/AutoCAD%202008/Autodesk.Interop.AcInetEngine.DLL
AdInfoCenter.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%202008/en-US/AdInfoCenter.resources.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
aphetrec
AcLayer
CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AcLayer.DLL
AcMgdShared
CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AcMgdShared.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%202008/en-US/AcLayer.resources.DLL
Autodesk.Interop.WSCommCntr1
CodeBase: file:///C:/Program%20Files/AutoCAD%202008/Autodesk.Interop.WSCommCntr1.DLL
Autodesk.Interop.WebServices1
CodeBase: file:///C:/Program%20Files/AutoCAD%202008/Autodesk.Interop.WebServices1.DLL
System.Web.Services
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
  • From the sounds of it, I would say that one of the components is damaged.  To test this out, I would recommend opening a different drawing, one with some components in it already (or just create a new one, add components, then reopen it) and see if you get the error again.  I woud then check the damaged drawing on another machine.  If it cause the error on a different machine and other drawings don't get the error, chances are its one of the components or part of the drawing's Xdata.  The next step would be to run the Repair command from Relationship Manager on the drawing to see if that cleans it up.  You could also try doing a save as to rebuild some of the Xdata to see if that cleans it up.  There is also the AutoCAD commands Audit and Purge to clean up some issues.  Try these things and let me know if any of them fix the issue or not.
  • Hi Rich,
    This is a bizzare one, sometimes I open the drawing and it throws the error and sometimes it does not...
    It started while I was working an issue with Ron - see ST8000474303.  Just thought someone in this forum might have run in to it as well.  If I can figure our what I am doing when it happens I will post further -
