Regarding the AP Project Information Differs dialog is there a configuration setting that will force the choice to Yes without user input?
I don't need to see this dialog in this case (I moved some P&IDs between project roots - and don't want to select Yes on hundreds on P&IDs).
Selecting Yes will connect to the current workspace project database
Selecting No will connect to the drawings database.
Hello Dave,
Thanks for posting your query to Bentley Plant Forum.
Please refer below wiki article that explains important setting to perform conversion of AutoPLANT PID to OpenPlant PID in batch mode.
If your issue still persist, please create a service request so that proper analyst can reach you to solve your concern. Refer below wiki link to raise a SR.
Regards | Deepak Singh
