I could open my opse normally yesterday, but I could not open it today, and it raise an system fault 99?
How to solve it?
Hello Abner,Which Version of OPSE V8i you are using?Regards | Jaya
Hi, Jaya
The Version is 08.11.11.93.
I also have an Additional issue. when click the menu "file-item", the software also will crash. You can have a try.
The Item Brower error has been solved. It seems that PW Client must been installed pre.
Answer Verified By: abner
Reinstall the OPSE, and the question is solved.
