I've had an open Bentley Service request going on 3 weeks now, which Bentley has been unable to resolve. I'm getting an "Invalid procedure call or argument" error when using Project Packager. Has anyone ever seen this error and been able to resolve the issue?
Hello Russell,Are you using ProjectWise here, If yes, is it a Managed Workspace?From error message, it looks like the Document are not Picking form ProjectWise. We re looking into this, will update you soon.Regards | Jaya
Hello Russell,Which ProjectWise Version you are using? Try to define working directory in some location like d:\workingdir\... and then try to Copy Out your file & Package it.Try this, hope this will work.Regards | Jaya
I'm PW using Version 08.11.11.590. It's only a few of our projects that Project Packager is having trouble with. All other projects work as designed. The lack of any error code in the error log makes it difficult to determine the problem or where the script failed to execute. It would be helpful for users if the programmers put more information as to where and why the script failed.
