I have to create a PE fitting to attached the a flange off a ball valve. The Polyethylene pipe in this instance coming off the valve won't have a tag as it isn't required. How can I do this?
Hello Joshua,On which Product you are trying to create PE fitting, also let us know the version of the Product?Regards | Jaya
Hi Jaya,
I have found a solution from a collegue. Thank you anyway.
Hello Joshua,
Thanks for quick response here. I was wondering what solution you get from your colleague. Can you please share the details for our knowledge?
Are you looking to not tag mating flange which is connected to PE components? Please help on this.
-Regards | Rahul Kumar
Rahul Kumar
