使用OpenPlant Support Engineering绘制了组合吊架,在生成图纸的时候出现如下图的错误,希望能提供技术支持。
The combination hanger is drawn with (OpenPlant Support Engineering). The error of the following figure appears when generating the drawing. We hope to provide technical Support.
Dear 士杰 侯,
Thanks for posting your query on Plant Forum!
Can you please provide some information here?
A. What is the version of OpenPlant Support Engineering you are using?
B. Is this customized Hanger assembly, or you are using default one.
C. Also please describe the steps you are actually trying to create Support drawing.
D. Also Please share your DB file to reproduce this issue at our end.
HTH
-Regards | Rahul Kumar
Rahul Kumar
A:使用软件版本:
A: software version:
B:使用的环境如下图:支吊架库使用的是中国 华东院开发的DZD 2010版本的支吊架库
B: the environment used is shown in the following figure: the DZD 2010 version of the support hangers library developed by east China academy of sciences is used
C:步骤是,选择,然后左键双击选择模型中的组合支吊架,直接跳出出图截面,然后跳出出错窗口。
C: the step is to select, and then double-click the left button to select the combined support hanger in the model, and directly jump out of the graph section, and then jump out of the error window.
D:DB文件可以咨询BENTLEY中国区技术人员提供。
D:DB files can be provided by the technical staff of BENTLEY China.
