How to display valve's name in iso drawings.
Hello David,
Thanks for posting your query on Plant forum!
I can see you have already achieved the tag name inside iso drawing. Is this what you want to achieve and it is written manually in drawing?
Normally this IE_TAG carries NAME property on Valve class which do not hold the tag information and hence different tagging. However you can use below below wiki article suggested by Jaya and let us know your feedback on this.
HTH,
-Regards | Rahul Kumar
Rahul Kumar
Hello Rahul,
I had achieved the tag name by Note,and I know there is a better way to do this.
Jaya has told me,and I did it now. thank you for your reply.
You can try above wiki article and inside User label dialog box, mentioned as listed below which is taking the definition from schemaInclude - IE_TYPE=CT_VALVE_STRAIGHTText - $(IE_ValveTag)Type- NOTECell Name - NOTE
Please let us know if any assistance would require.
