New to OpenPlant, but not workspaces so please be gentle, and have taken the project pcf file and included it in our build as a cfg and customised the paths. PAthing is fine, but when I start OPM I get the error below. Any idea on what I need to check out? Thanks.
Hello Bear,
You may refer below wiki on this to give you some idea on such error types. Mainly first use case would help, by opening class editor and check it further if something goes wrong.
StartUp Error-Launching OpenPlant Modeler Applies To Product(s): OpenPlant Modeler Version(s): 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) Environment: Windows 7/8.1/10 (64 bit) Area: Start Up Subarea… Last edited over 6 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
However you may also please upload your workspace for us to investigate the matter.
Link to upload workspace - https://bentley.sharefile.com/r-r549b80ab79443429
HTH
-Regards | Rahul Kumar
Rahul Kumar
Thanks for the quick reply Rahul. The error is the same as the first, but in the OpenPlant_3D.01.07.ecschema.xml file I have. This file opens without error in Class Editor. More digging required.
Rahul, the issue appears to be that is can't find referenced schemas. I see this in Class Editor as well. How can I fix this issue?
Could you please take a snapshot of the error, while opening the schema in class editor, and attach here? Also, if you could send your OPenPlant_3D.01.07 schema may be we can fix it.
Regards,Harpreet
I hope there's not much to fix, I haven't edited the schema yet, it's a fresh one from OP Admin.
