When using Modify Label on an Isometric extracted to 2d, the arrows behave 'badly'
How to fix ?
We are running OP Isometric Manager S6 08.11.11.293
Hello Peter,
08.11.11.293 build was created to fix some problem for certain users. Please check it with 08.11.11.285 release build and confirm your result.
If there is still an issue then may I please request you to create a service request for this to enable us to talk further to development team and log a Defect to this item?
HTH
-Regards | Rahul Kumar
Rahul Kumar
This is the version we were running, hoping that 08.11.11.293 would solve this also.. Sadly no..
Thanks for quick update.
Like we said earlier 293 build was meant for specific cause. Kindly raise service request with details. We will log Defect for this.
HTH,
