Batch add new pipeline numbers in OPM?
I have a model with a few hundred line numbers.  All with the same properties (size, spec, system).  Do I have to add each line number individually, or is there a way to have pipeline manger generate multiple new pipelines in a single command?
Example:
1"-SYS-CS150-001
1"-SYS-CS150-002
continue through...
1"-SYS-S150-200
Hitting: create new pipeline, Properties, enter Number, Save for each individual pipeline is taking forever!!
Mike McGinnis
