How do I place a lug style butterfly valve between FF weldneck flanges with no gaskets? In the model, I can hit 'cancel' when gasket selection dialog appears, and geometry is placed, but Isometrics manager sees it as a disconnect, and will not generate an Iso sheet.
Hello Mike,
Do you want to hide Bolt/Gaskets or you dont want in the Model?If your requirement is to hide Gaskets then you can Turn Off Construction Tab from View Attributes, see below Wiki Article.
If you dont want Gaskets in OpenPlant Modeler as well as in Isometric you can refer below Wiki Article.
Removing Gaskets from Schema
Regards | Jaya
I believe second wiki suggested here would help in case of joint. Neglecting the selection at the time of query dialog would not help and certainly it shows as disconnect, unless you manipulate Joints.
HTH,
Rahul Kumar
