Is SS7 in the pipeline for openplant? or it'll be only Connect moving forward?
Best regards,
Tuan Le
Just looking at the announcement forum, it looks like there exist something called Openplant CONNECT Select Series 6. So for Openplant, Connect and SS had become 1? For ABD, Connect is a separate platfrom from Select Series.
And then there are "refresh" releases as well as "update" releases. It would be greatly appreciated if I can get some advice why the different terminology?
I'm asking because we are at the crossroad of evaluating upgrade from OPM SS6 08.11.11.103 to either SS or CE. If SS has ended, then it's a no brainer we have to invest looking in CE.
Hello Tuan Le,
Can you give that link here. It would be quick for you.
In my suggestion: SS relates to v8i and CONNECT is a separate edition.
HTH,
Rahul Kumar
Hi Rahul,
Link is below
https://communities.bentley.com/products/plant/f/autoplant-axsys-openplant-plantwise-announcements-forum/136645/release-announcement---openplant-v8i-connect-services-selectseries-6---refresh-2
Although it looks like it could be a typo in the announcement title.
Is there any advice on the future of the V8i platform? And the difference between "refresh" and "update".
Yes,
So far we are using Refresh version for v8i release and Update for CONNECT Edition release.
On Future development for v8i, I would suggest may write directly to Product Management Abbas Ali <abbas.ali@bentley.com> or Rob Harper <Rob.harper@bentley.com>
Thanks Rahul, so just to confirm, SS and Connect are still separate platform in Openplant?
