I understood that in new version of OPIM (10.01.00.23) user can assign custom levels for reports (SHP, FLD, CUT, ...).
How can we do that?
I tryied to assign levels for reports text node, but the result was that level assigned only for the text node and not for the report.
Hello Avi,
Thank you for your question. You have done all those changes in your OPIM style seed file?I will check this same situation in my Out of the box environment with this same OpenPlant Isometrics Manager CONNECT version.
Will update you as soon as I will find answer for you.Regards,Kestutis Mitkus
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
Thank you for your answer Kestutis.
I have done it in seed file of default mix metric project, IFC style.
I'll wait for your reply.
Why you want to use Level change for Bill of Materials report? Is there any special reason or requirement?
On first look I understood that you want to change Looks of your text and for this purpose I would like you to suggest checking this wiki:https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/23841/how-to-change-bill-of-materials-list-s-text-font-size-color-and-location-using-text-nodes
Else answer for us with more information about why and what exactly you expect to get from this level change?
Thank you in advance and looking forward to hearing from you.
Hello Kestutis,
User needs this option because they developed some applications on top of older versions of AP and IsoGEN, which point to specific coordinates in isometric drawings, which also filtered by Spec for example, and calculates only from these filtered drawing the reports they need.
The reports in any drawing where in specific coordinates and their layer was not shown in isometric drawing itself.
The user also wants to be able to turn on and off the report levels in the isometric drawing.
We can change levels for all text nodes, except that in text node of reports it does not work properly.
He already had SR on this subject. We understood that this should be accessible in the new version of the software.
I assume from your reply that it is not :-/
