Hi All, I can't be the first to do this so I hope there is a manageable work around,
So I've been building specs in AutoPLANT for 20 odd years, and I'm finally moving over to OpenPlant Spec-Gen with the old AutoPLANT specs/Catalogs to convert and use in OPM
Catalogs - I can see that there is an exchange for AutoPLANT to OpenPlant catalogs, which seems to strip out a lot of fields in the catalog's that are not required, and yes I had to fix the mm as per another post.
Specs - I don't see anything except the Upgrade to OpenPlant that adds the extra field into each Spec. I can open an old AutoPLANT spec in OP Spec-Gen and then assign a new OP Class Name but then part of the filter disappears, mat_grade. Previous in AutoPLANT it use the SpecGen-Settings.mdb to read the list of materials and then you could use this to build long descriptions in AutoPLANT. But I can't see this in OpenPlant the field is missing and all of my descriptions use this field.
Below shows the AutoPLANT spec as it is loaded in OP Spec-gen then after the CLASS has been selected the fields that don't exist are removed including Mat_Grade which in AutoPLANT is not sourced from the Catalog.
I hope the answer is not to rebuild all of these specs again, or create catalogs from the AutoPLANT specs.
Hello Ray,We are discussing this concern internally with OpenPlant & AutoPLANT team.However, can you please let us know which version of Spec Gen you are using?Regards | Jaya
Hello Ray,
I would like you to ask creating new Service Request, because this is specific issue for which we will need to do investigation and search for possible causes. Please attach this same specification and all used catalogs while creating Service Request and our specialist will try to find out what is failing.When we will find the cause will update this thread as well.
Thank you in advance.
RegardsKestutis Mitkus
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
OpenPlant Project Administrator 08.11.11.225
OpenPlant Spec Generator 08.11.11.225 (FYI it crashes for no reason constantly)
OPIM 08.11.11.285
OPM 08.11.11.304
Submitted - Request number 7000843586
Unfortunately, I haven’t found any way how to convert AutoPLANT specifications to OpenPlant. We have only Upgrade to OPM option which as stated in Help Contents is not converting specification and after upgrading it can’t be edited in SpecGen.
As you can see this option is only upgrading spec to be usable in OPM, but it does not update specification tables and after trying to edit it removes all data.
In this current situation you have few options:
I hope this information will be useful. Please let me know if you need additional help on this topic or if you have other concerns/questions.
