Hi Gents
I am looking for a method in OPM, when we placed a support location, is possible to catch the support number of the support location to the cell name? e.g. in element properties,
Cell Name = Name as shown the illustrated fig below, can you give some tips how can I make it? I know there maybe some function in class editor, it maybe can add some formula/expression.
I want the parameter "Cell Name" got the name as in OPM support location attribute automatically.
3107.Empty.dgn
Cell Name is a Microstation property and OPM doesnt have control over it because its not available in OPM Schema. But if you try to rename the CellName from Element Info by Double Clicking the name "SP-3" it takes that name into your Cell Name property. So OPM is not doing a good job of reading the actual cell name and putting it on the Microstation Cell Name property. You can fix this by writing an MDL application which will 1) scan every component in the DGN 2) Read Its Name/TAG property 3) Write it on the Cell Name property.
Answer Verified By: Rahul Kumar
Hi Sir
can you show me some code for this? I just need a short sample and then I can deep in further myself.
If that possible?
You need to do something like below.
ScanCriteria* pScanCriteria = mdlScanCriteria_create();
mdlScanCriteria_addSingleElementTypeTest (pScanCriteria, CELL_HEADER_ELM); mdlScanCriteria_setReturnType (pScanCriteria, MSSCANCRIT_RETURN_FILEPOS, FALSE, TRUE); mdlScanCriteria_setRangeTest (pScanCriteria, NULL); //no range test mdlScanCriteria_setModel (pScanCriteria, ACTIVEMODEL); /* loop through all Titel cell elements in file */ do {
//once you get a cell name here..you need to use EC Framework APIs to extract the EC data and get the Name of the element.
and then use MDL APIs for changing the cell name Property.
Answer Verified By: You Quanwu
Thanks a lot, I will try it later.
Hello Yuanwu,
Here is the MVBA code for your reference.
Sub FillCellNameAsTag() Dim Mycell As CellElement Dim ee As ElementEnumerator Dim sc As New ElementScanCriteria sc.ExcludeAllTypes sc.IncludeType msdElementTypeCellHeader Set MyEnum = ActiveModelReference.Scan(sc) Do While MyEnum.MoveNext Set Mycell = MyEnum.Current Select Case GetCellProperty(Mycell, "SUPPORT_NAME") Case "NotAvailable" Case Else SetCellProperty Mycell, "CellName", GetCellProperty(Mycell, "NAME") End Select Loop End Sub Function GetCellProperty(CellEle As Element, PropertyNameString As String) As String Dim OPH As PropertyHandler Set OPH = CreatePropertyHandler(CellEle) On Error Resume Next GetCellProperty = "NotAvailable" OPH.SelectByAccessString (PropertyNameString) GetCellProperty = OPH.GetValue End Function Sub SetCellProperty(CellEle As Element, PropertyNameString As String, PropertyValue As String) Dim OPH As PropertyHandler Set OPH = CreatePropertyHandler(CellEle) OPH.SelectByAccessString (PropertyNameString) OPH.SetValue PropertyValue End Sub
