I get the following error message when extracting Isometrics from OPIM 'Error[0]: no DEF entry for scaler type DUMMYPIPE'
I am using Autoplant Modeler V8i SS8.
Hello Chidiebere,Can you please check Scalar file in your Dataset 'symbolsizes.def file' whether Dummy Pipe is present inside symbolsizes.def file?If No, then you can find it from default Dataset 'symbolsizes.def' file, see below image. Copy that & paste it inside your working symbolsizes.def file.
Then try to extract isometric.Hope this will help.Regards | Jaya
Hello Jaya,
Thanks for your prompt response.
The problem have been solved. Meanwhile, what is the function of the file 'symbolsizes.def' ?
Chidi
Hi Chidiebere,
Symbol size.def is used for Scaling the OpenPlant Modeler components.We also have Wiki Article for this Error message.
Regards | Jaya
Hi Jaya,
Please can you send the link to the Wiki article. Thanks.
I have attached Wiki link in previous comment. But still you can see on below link.
Wiki Link:
