How to continue BOM numbering between sheets
I have an pipeline split between two sheets. Split was done by OPIM and I noticed that BOM numbering starts again from 1 in sheet 2. Is there a way to continue the numbering between the sheets? Now in same pipeline there is components with same part numbers which can cause some problems during manufacturing at site. Eg. in sheet 2 the numbering should start from 4, not from 1 again.
BR
Tuomas
