Add pipeline property value to pipeline ISO continuation label
How can I modify the pipeline continuation label so it will display the value of property DWG_NR under pipeline properties? DWG_NR is a custom property added by myself.
Currently the Continuation label shows the name of pipeline but it would be more useful if it will show the property DWG_NR contents, which in this case is DWG-12345. Is this modification possible?
