Hi Guys,
Please I need your help, I have the propdlgs.zip and I unzip the files and then I use Visual Basic and I created a New Form At_EqFilt and I created a new TextBox the name is Epow that is the existing Attribute in the EQUIP table, but the problem is when I test in Data Manager and check the information the dialog box appear turn off, check the pictures below
This picture is in Visual Basic
In Data Manager (the dialog box appear Turn Off) the Attributes is Epow EQUIP Table
Best regards
Dear Enrique,
can you attach the files here as well? However we will inquire and update you shortly on this.
HTH,
Rahul Kumar
Answer Verified By: enrique miyamura
Hi Enrique,
Thank you for the live meeting and for demonstrating your issue.
To resolve the issue we opened the RebisComponentDialogs.vbs file in Visual basic, modified the Maximum Length of the Property.
Recompiled the DLL file and restarted the Data Manager. This resolved your issue.
Regards | Swapnil Joshi
Answer Verified By: Rahul Kumar
