How to create plane?
I`m pretty new to OpenPlant Modeler and having problems finding basic stuff. Like how you create Origin or how to Place a plane? Is there a tutorial I can use?
We use building model as reference and we place other components such as pipes and equipment. I need to create multiple elevation planes based on the referenced plant model.
How I do that?
Thank you.
  • Hi Alex,
    To create a new origin please find the below mentioned wiki article which is for MicroStation but will work for OpenPlant Modeler as well.
    Document Information Document Type: FAQ Product(s): MicroStation V8 2004 Edition and previous Version(s): All Original Author: Bentley Technical Support Group Legacy Document Number: 6314 …
    3 comments
    There is also a forum link for a similar requirement.
    Hello, I am new to Microstation V8i SS2. I am trying to move a line so the beginning point of the line is set at 0,0,0 point in my model. I have selected the line, selected move, selected the endpoint…
    By in MicroStation > MicroStation Forum
    To add planes to confine the drawing we have Clip Volume Tool. Kindly refer the wiki article mentioned below which would help you regarding the same.
    clip volumes and display styles
    Regards | Swapnil Joshi
    Answer Verified By: Alex Shmidt
  • Hi Alex,
    We have investigated your concern further and have found a perfect article which would guide you to create a new origin or place a plane.
    Overview The ACS tools have been significantly improved in current versions of MicroStation-based products. In fact, ACS actually replace the need for Depth Lock (note that Depth Lock has been removed…
    Kindly follow the same and let us know if you require any more help.
    Swapnil Joshi
