Add pipeline to support reports in OPM SS6
I'm running reports in OPM SS6 in which I have listed all supports located at the model. Is there a possibility add a column to the report which shows also the pipeline in which the support is located? The pipeline -property is not found under the Edit Report/Properties To Include -dialog.
BR
Tuomas
