I do have a model of pipe run from one tank to another . It has 2 pipeline numbers. I have no problems creating iso sheets for these runs. It splits them automatically and provides end labels so I know which sheet to look on.
I was wondering how can I create one iso sheet with both pipelines on the same page? I don`t see an option for it.
My second question would be : how to eliminate suffix at the end of generated isosheets? -iso-1,2,3 etc?
Thank you.
Hello Alex,For your 1st Query: I was wondering how can I create one iso sheet with both pipelines on the same page? I don`t see an option for it.Currently, it is Not possible. But still we are looking into it.2nd Query: how to eliminate suffix at the end of generated isosheets? -iso-1,2,3 etc?It is possible, we have a Wiki Article for this sending you in short time.Regards | Jaya
Hello Alex,
Please refer below Wiki link to format iso-sheet output name in OpenPlant Modeler
To Change Isometric Output Drawing Name Format Applies To Product(s): OpenPlant Isometrics Manager Version(s): 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) Environment: Windows 7/8.1/10 ( 64 bit & Others) Area: Settings… Last edited over 5 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
HTH
Deepak Singh
Dear Alex,
Like suggested below by Jaya and Deepak,
1. Iso sheet generations are based on Pipeline. Pipe run concept is not applicable in OpenPlant Modeler.
2. On second query Iso-NUMBER is a combination of Static text 'iso' and property NUMBER, which primarily helps to distinguish isosheets during the split of a pipeline when there are multiple fittings and components associated with that pipeline and thus to reduce the elements it require splitting and hence the nomenclature. However if there are other ideas you may definitely pursue it as per wiki link provided below:
HTH,
Rahul Kumar
