I am using Autoplant Modeler V81 SS8 version 8.11.13.245.
Can someone help me with the step on how to generate equipment layout from the 3D Model. It is very urgent. Thanks.
Chidi
Hello Chidiebere Okeoji,
Thank you for posting this question to our Bentley Communities.Could you please add here few screenshots of your Equipment and as well some example what equipment layout you would like to get?by default you can use Work Area and create required View.In below wiki you can find useful information about this:
Regards,Kestutis Mitkus
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
Hello Kestutis,
Thanks for your quick response. Below is a snap shot of a section of the equipment to be laid out.
Also attached, is a pdf copy of how the layout should look like. Obrigado.
3580.OKG-K066-PIP-LAY-NET-000-00101-00 Rev U06.pdf
In you attached PDF I can see very complex model, which has various disciplines in one model. It has Building, Piping, Equipment's, HAVAC, Annotations, Border, Dimensions and more. On your picture I can see a top view of your Equipment model together with piping.If you want to create such layout without anything additionally referenced, then you can use same Wiki which I posted and then you can create required views, place all tags and annotations.We have very good Learning Material on our Learn Server about how to create and Use Work Area Views an there you can find much detailed information with Videos of how to create various Layouts just by creating required Work Are Views.
Best RegardsKestutis Mitkus
Am wondering why I cant access the Learn Server. Could you help me out please. Thanks
Hi Chidi,
Kindly try the link mentioned below.
Regards,Swapnil Joshi
