Looking for updated custom.cel or lisocomp.cel for OPIM
The out of the box cell blocks don't match the old ISOGEN skey.
Example the end type SW (socket-weld) shape in the new OPIM have strange triangle teeth off the end.
Before I do spend a bunch of time making these shapes as expected on an Isometric,,,, Has any one already done so?
Thanks for your attention
J
Hello J Rogers,
Can you please confirm the version of OpenPlant Isometrics Manager you are using?
Are you looking to upgrade all SW shape present in lisocomp.cel? Can you please share what type of shape you want to have for SW End?See default end Preparation defined in template:
HTH,
Rahul Kumar
We are running opim081111285en
Attaching an example of the Flanged Threaded (Screwed) from previous ISOGEN (White) to the OPIM FLNSCF, Flange Threaded (Black)
You need to manually edit the list containing with an end prep FLNSCF and to other SCF wherever it is present or likely to be used. As these default cells are for reference use only and user may change it as per their project.
Ideally user creates their custom cells and store it in custom.cel using templates available in OPIM folder. Below path to access:
You may also refer below wiki article where similar steps are described on using templates and modifying/creating cell for custom use.
How to Use Custom Cell as User Labels For Instrument Symbol Applies To Product(s): OpenPlant Isometrics Manager Version(s): 08.11.09.xxx Environment: Windows 7 (64 bit) Area: Settings/Attributes Subarea: Modify Symbol-… Last edited over 7 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
