Is there an option to remove a section/subcategory from the Spec? There is definitely an option to add but not to remove.
Thank you
Hi Alex,
Thank you for posting your query in Bentley Plant Forum.
Please refer the wiki article mentioned below which has more information on removing sections from spec.
How to Delete-Modify Sections in Specification Generator Applies To Product(s): OpenPlant Modeler Version(s): 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) Environment: Windows 7/8.1/10 (64 bit) Area: OpenPlant Specification Generator… Last edited over 6 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
Hope this Helps.
Regards | Swapnil Joshi
Answer Verified By: Alex Shmidt
