I just received a new machine and I am having issues with my pipelines appearing as wireframe in Navisworks. I am running AutoCAD 2017, AutoPlant 8.11.14.124 and Navisworks Manage 2018. I also have Object Enabler V8i for AutoCAD 8.11.14.124. I have looked online and it was suggest to uncheck "use ADT standard configuration" which I have done. Any other suggestions?
Hello AHolfeld,
We will get back to you shortly. Meanwhile you may refer below articles
Bentley AutoPLANT and Navisworks Applies To Navisworks users who need to view AutoPLANT graphics Product(s): AutoPLANT Piping / Equipment / Modeler Version(s): 08.11.10.182 Environment: Windows 7 32 bit, Windows… Last edited over 5 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki 7 comments
AutoPLANT Modeler CONNECT /V8i Object Enabler for AutoCAD Applies To; Product(s): AutoPLANT Modeler V8i /CONNECT Object Enabler Version(s): SS6 (08.11.11.135) | SS7 (08.11.12.226) | SS8 (08.11.13.129/211/08.11.14.01) Environment: Windows… Last edited over 1 year ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
HTH,
Rahul Kumar
Hello Ashley,
Thank you for the concern. Please check with the below given changes need to be carried in Option Editor in NavisWorks.
Once the above changes done please reopen NavisWorks and open model to view It.
Regards,Vidit Ruhela Product Engineer
Are you a CONNECTED User? Click here to find out more.
Find out whats inside Connect Advisor Update 2. Click here
Produce 3D models of existing conditions and Bring them to life!!
The Dwg Loader Version is greyed out, it states 2018.
Please change Render Type to Automatic as shown in attached screenshot and check for the result an let the DWG loader to 2018 as its greyed out.
I get the same results
