How to place a weld between 2 components if they are not perfectly lined up?
For example I have a sloped pipe (see below) and a horizontal pipe with a few elbows in between. The last elbow end that connects to the tee is not parallel to that tee, therefore weld wasn`t placed.
  • Hello Alex,
    Please use the variable OPM_MISALIGNMENT_ALLOWANCE in pcf file to adjust dynamically misaligned fittings on pipe. below article to refer where it enlist popular OpenPlant Configuration variable.
    HTH
    Rahul Kumar
    Product Engineer | Community Moderator
    Are you a CONNECTED User? Click here to find out more.
    Find out whats inside Connect Advisor Update 2. Click here
    Produce 3D models of existing conditions and Bring them to life!!
