I'm looking for a way to convert Autoplant Solid (like AT_Cylinder) to a regular Autocad solid.
Problem is that the model doesn't have any intelligence. It was make on Autoplant V8i but the Database isn't there anymore so Autoplant won't open it. I can't even force a new project or anything.
Any ideas ?
Other question, is it planned to see Autoplant Object Enabler to be released ? If yes, when ?
Thank you
Rémi
Hello Remi,
Thanks for posting your question.
Could you please clear my below doubt regarding your concern.
1. In which Application you are trying to open AutoPLANT Model?
2. If you are trying to open Model in AutoCAD. Mention the AutoCAD Version?
3. What Version of Object Enabler you are Looking for?
If possible provide us AutoPLANT Model, so we can guide you proper direction.
Looking forward to your reply.
Abhijit Bute
Hi Remi,
There is no process to convert AutoPLANT solid to AutoCAD solid. But the AutoPLANT components can be viewed without issues in AutoCAD if Object Enabler is installed.
Please find the link to download a relevant Object Enabler based on the installed AutoCAD version.
AutoPLANT Modeler CONNECT /V8i Object Enabler for AutoCAD Applies To; Product(s): AutoPLANT Modeler V8i /CONNECT Object Enabler Version(s): SS6 (08.11.11.135) | SS7 (08.11.12.226) | SS8 (08.11.13.129/211/08.11.14.01) Environment: Windows… Last edited over 2 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
Hope this helps.
Regards | Swapnil Joshi
Thank you for the replies
Abhijit Bute said:1. In which Application you are trying to open AutoPLANT Model?
I'm trying to open Autoplant Model in Autoplant V8i. But those model had been archived without database. To convert them into solid. The idea is to be able to see them on Autocad 2019. No object enabler 2019 had been released at the moment.
Abhijit Bute said:3. What Version of Object Enabler you are Looking for?
Object Enabler Autoplant 2019, is it going to be released ?
Object enabler for AutoPLANT 2019 expected to be available on mid of Feb. 2019.
AutoPLANT has a command COPYASACIS that may help you. It will create a copy of an AutoPLANT entity as an AutoCAD solid on whichever layer is current.
