I'm trying to expand my model creation vb to import service and unit when a model is created.
I'm using the keyin mentioned here:
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/8569/how-to-import-unit-service-pipeline-instances-from-a-text-file-to-an-active-dgn-file
But what I would like to do is use:
OpenPlantModeler Import <Class Name> <Path and file>
Is this even possible? I can't seem to find a way to get the path to work in the keyin.
We will inquire and update you the possibilities.
HTH,
Rahul Kumar
Thanks.
Unfortunately the keyin does not support the file path option. @Rahul Kumar we can log an enhancement to support file path option so that users can automate the import process.
Please go ahead and file the enhancement.
I would also suggest that this sort of this should not be file based and should be part of the system, read from the OPM build. I'm a little lost as to why this sort of information in stored in the file.
