We are using AutoPLANT with OPIM. In one of our projects we have AT_PLINE_PIPE spools, some of which are flanged and some are not. The flanged spools accumulate as a count in the iso BOM while the non flanged spools accumulate as a total length. We would like the non flanged spools to accumulate as a count as well. Since the flanged spools already accumulate this way it leads me to believe that the accumulation method is dictated by the spool's end conditions. I looked in the schema but can't tell where this is controlled. How can I get non flanged AT_PLINE_PIPE spools to accumulate as a count rather than length in the OPIM BOM?
Hi Marc,
Thank you for posting this query here. Which AutoPLANT and OPIM versions you are using?
Regards,Kestutis Mitkus
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
Hi Kestutis,
We are using AutoPLANT Modeler SS7 08.11.12.252 and OPIM 08.11.11.294
I figured it out. Here's how I ended up getting it to work:
- Use a Weld Value Map to map AutoPLANT end code FLR (Victaulic Rubber End) to the VICTAULIC_PLAIN_END property.
- Change the scaler and symbol for pipe so that all lined components export as PIPE-FIXED and use a PIPE + IM.EndPrepMap() symbol
Scaler: IIf(this.MODULE = "at_pline", "FIXEDPIPE,1", IIf(IM.MapText("PIPE" & IM.EndPrepMap()) = "PIPE","PIPE,1","FIXEDPIPE,1"))
Symbol: IIf(this.MODULE = "at_pline", "PIPE" & IM.EndPrepMap(), IIf(IM.MapText("PIPE" & IM.EndPrepMap()) = "PIPE","PIPE","PIPE" & IM.EndPrepMap()))
-Since FLR is now mapped to PE create a couple of new symbols: One for PIPEBW_PE and one for TEEPE_PE_FL
Answer Verified By: Rahul Kumar
Hello Marc,
Thank you very much for posting the solution here. Hope this can work with Latest AutoPLANT Modeler version too.
