At the moment of extracting isometrics, the following message appears:
I would like to know what solution I can give to this problem,
Dear Milthon,
thanks for posting your query on Plant Forum!
Refer below similar wiki where various cases has been illustrated.
Scaler, Symbols or Item code are missing for TAP_CONNECTION error message when Branch Connected Through... Applies To Product(s): OpenPlant Isometrics Manager & AutoPlant Modeler Version(s): 08.11.09.458 & 08.11.11.135 Environment: Windows 7 (64 bit) Area: Settings/Attributes… Last edited over 5 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
Similarly please attach an image of Isometric Component custom attribute from class editor to check this at our end.
In case you are new on using class editor, then you may please log a service request to check over live meeting.
HTH,
Rahul Kumar
Thank you for your attention, you can indicate which of these schemes you are referring to:
Yes these are schemas which I was referring to. However you may also log SR as it require some investigation by analysts.
HTH
