Hello Guys!
I noticed while creating ISO drawings that some of the pipeline continuations have different labeling. Why on some pipelines I see CONN. on others CONT.
Why is that? I don't think I did anything different when creating pipe runs.
Please see below:
Hello Alex,
Thanks for the question. Could you please provide us the drawing model.
So that we can reproduce the same on our side and guide you on proper direction.
Abhijit Bute
Dear Alex,
Cont. On is a sheet continuation which means there are two more sheet created in drawing. However Conn. to is Pipeline label, which says its connected to different pipeline.
You can manage is through isometric configuration dialog as well.
HTH
Rahul Kumar
Answer Verified By: Kestutis Mitkus
While we are giving each other hoops to jump through, maybe you can explain to me what kind of response this is? Can these types of answers be avoided by opting for a premium support plan, or does this happen there too?
