How can I create a ECExpression that take de pipeline diameter?
Hello Masters of OP  ; )
I´ve to create a way to put in a field the name of my pipe system.
the tag names here are formed by:
PRODUCT: PpPp
NUMBER: 1234
SPECIFICATION: SSS
DIAMETER: DD
and, if existis, INSULATION: Ii
For example:
A pipe of cooling water (WaCl), with the number 2325, in the carbon steel specification (CS2), with 20 inches of nominal diameter and not isolated.
This results in: WaCl-2325-CS2-20".
ok, well I belive that is an possible solution:
this.SERVICE & "-" & this.NUMBER & "-" & this.SPECIFICATION & "-" & this.NOMINAL_DIAMETER& "-" & "´´"
to be edited in the EcExpression in the NAME properties of the Iso Sheet class (i want to show this on the isometric sheet).
Well, obviously, its not work at all...
so... I need some help, please...
and oh! thanks a lot!
