Hello Masters of OP ; )
I´ve to create a way to put in a field the name of my pipe system.
the tag names here are formed by:
PRODUCT: PpPp
NUMBER: 1234
SPECIFICATION: SSS
DIAMETER: DD
and, if existis, INSULATION: Ii
For example:
A pipe of cooling water (WaCl), with the number 2325, in the carbon steel specification (CS2), with 20 inches of nominal diameter and not isolated.
This results in: WaCl-2325-CS2-20".
ok, well I belive that is an possible solution:
this.SERVICE & "-" & this.NUMBER & "-" & this.SPECIFICATION & "-" & this.NOMINAL_DIAMETER& "-" & "´´"
to be edited in the EcExpression in the NAME properties of the Iso Sheet class (i want to show this on the isometric sheet).
Well, obviously, its not work at all...
so... I need some help, please...
and oh! thanks a lot!
Hello Rahul!And thanks for this answer!And see below the print of the error msg.:
Hello Dennis,
This is mainly because RegEx only validate the properties which are available on its class. Here SPECIFICATION is not available, hence missing.
For any property to cascade from different hierarchy to certain class, require different expressions. Try below expression to get SPECIFICATION to be applied on ISO_SHEET class.
this.LINENUMBER & "-iso-" & this.NUMBER & "-" & this.GetRelatedInstance("PIPING_NETWORK_SYSTEM_HAS_ISO_SHEET:1:PIPING_NETWORK_SYSTEM").SPECIFICATION
HTH,
Rahul Kumar
