So, I'm working in OPM at home, where I have only a single monitor. When I open the Pipeline Manager dialog, it is on my second monitor (at work I have three). We used to be able to go into the registry and change the "Left" value of dialogs to bring them back on the single screen. I've looked through the registry and can't find anything seemingly related to the Pipeline Manager dialog. I can't seem to find any other way of changing the value to get that dialog back on my screen. Anyone else have this issue? (It's been around for a long time!)
Hi Robb,
Thanks for posting your query on Plant Forum!
few suggestions here which worked for few users and you may try:
HTH,
Rahul Kumar
Hi Rahul,
Is there a solution to this? I have multiple users that are reporting this issue. Especially, in a hybrid work environment with changing monitor setups. The steps you have identified doesn't solve the issue. What can we do to force open Pipeline Manager on the main screen. I have tried deleting prefs and still have the same issue.
Best Regards,
Sujaan Fareed
Hi Sujaan,
I just tried ,moving to another monitor and then to use key-in 'pipelinemanager maximizemanager'
once I set to maximize it display's to main screen. Can you please try and update if that would help in anyway to your designers?
Thank Rahul! I think this is a good key-in to know. I will test it out when I have this issue again.
Hello all,
you can use a Windows Keyin to move the dialog to the right screen.
1. Open the Window List select Pipeline Manager
2. Press ALT+SPACEBAR
The following dialog should open for the Pipeline Manager. You may not be able to see it either.
3. Press M (equal to selecting the Move option) and the mouse cursor will turn into a cross with arrows and move to the title bar of the window.
4. Now, you can use the left, right, up, and down arrow keys on your keyboard to move the window to another position.
