Hello everyone,
I work on a project with different standards (3).For example, in my catalogs, pipe of 2''1 / 2 were input like this:76.0, 76.1 and 76.2in the "Standard Preferences" dialog box, the 3 diameters are visible as input.In the isometric diameters appears 2.5 and not 76.0 or 76.1 or 76.2How to change that.
Best regards
Hello Salim,
can you please attach images from OpenPlant Modeler as well as from OpenPlant Isometrics Manager?
Also please check how it displays in Element Information dialog.
HTH,
Rahul Kumar
Hello Rahul Kumar,
I did not explain explained my problem:
I work on a project with different standards (3).For example, in my catalogs, pipe of 2''1 / 2 were input like this:76.0, 76.1 and 76.2 or for pipe 3/4 '' => 19.05 and 23in the "Standard Preferences" dialog box, the 3 diameters are visible as input.In the isometric diameters appears 76 and not 76.1 or 76.2, for 19.05 => 19My wish is to be able to display integers as integers and real ones as real.Is it possible to change that?
Best regards, Salim
Thanks Salim for your input here.
this may require your workspace to investigate the type of style, schema customization or any catalog issue. Please create SR for the same.
-Regards | Rahul Kumar
