Does anyone know if there is a way to change OpenPlant PID, so when two electric instrument lines connect together it`ll place a dot (bigger dot/circle see below) ?
Thank you.
Hello Alex,
Thanks for posting your query to Bentley Plant Forum. We are looking on the possibilities to achieve such requirement, will keep you posted on the possible solution.
Regards | Deepak Singh
This issue is in discussion through Service Request 7000880002 & possible solution has been communicated on it.
ThanksRegards | Deepak Singh
Answer Verified By: Alex Shmidt
